| Siebel Applications Administration Guide > Global Target List Management >  Editing Target Lists (End User)
 You can add and delete records from saved target lists. This task is a step in Process of Managing Global Target Lists. To edit a target list
Navigate to the List Management screen, then the Lists view.
To navigate to this view, you can click Save and Edit in the Save to List dialog box described in Step 4.Drill down on the List Name field for a target list record.
Navigate to the appropriate view as described in the following table.
    | If the Target List Contains... | Then Use This View to Add or Delete from the List... |
    | Accounts | Accounts |
    | Team members | Positions |
    | Contacts | All Contacts, My Contacts, or List Contacts and Prospects NOTE:  The My Contacts view filters the list to show only your contacts. |
    | Employees | Employees |  |
