Siebel Applications Administration Guide > Global Target List Management > Applying Target Lists (End User)After you or an administrator create target lists, you can apply them. To apply a target list, you must be in a target list-enabled view. When you apply a target list to a view, you do not add the records in the list to the view. Instead, you restrict the records that you can add to the view to only those records that exist in the target list. This task is a step in Process of Managing Global Target Lists. |
| Siebel Applications Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
