Siebel Applications Administration Guide > Global Target List Management > Creating Activities from Target Lists (End User)From the List Management screen, you can create activities for each member in a list. How fields for the activities are completed, including which fields are copied from the list member records, is determined by "activity templates." These templates are set up by the Siebel administrator. In the preconfigured Siebel application, the "activity templates" can be applied only for lists of contacts. For more information, see Setting Up Data Map Object "Activity Templates" for Target Lists. This task is a step in Process of Managing Global Target Lists. To create an activity for each party in a list
| Siebel Applications Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
