Siebel Applications Administration Guide > State Models > Configuring All Operations for Child RecordsBy default, users cannot delete child records when the No Delete field is selected for the state value of the parent record. Also, by default, users cannot add and modify child records when the No Update field is selected for the state value of the parent record. Enabling All Operations for Child RecordsTo override the default behavior, administrators can complete the following procedure to enable all operations for child records. To enable all operations for child records
Disabling All Operations for Specific Child RecordsAfter they enable all operations for child records, administrators can complete the following procedure to disable all operations for specific child records. To disable all operations for specific child records
Enabling All Operations for Specific Child RecordsTo override the default behavior, administrators can complete the following procedure to enable all operations for specific child records. To enable all operations for specific child records
| Siebel Applications Administration Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
