| Siebel Applications Administration Guide > Web Services >  Printing or Sending Mail Merge Messages
 After you preview your mail merge messages, you can merge all of the messages to one Word document, send all of the messages to a printer, or send all of the messages as email messages. This task is a step in Process of Using Word Web Service to Perform a Mail Merge. To print or send messages
Open the Word document to which you added a data source in Getting the Data for a Mail Merge from the Siebel Database.
Click Print or Send Message, and then select one of the menu items described in the following table.
    | Merge to Document | Merges all records from the data source, and adds each merged document into one Word document. |
    | Merge to Printer | Merges all records from the data source, and prints each document. |
    | Send as Email | Merges all records from the data source, and emails each document to an address specified in the data source. Use the Merge to E-mail dialog box to specify the field where the email address is stored in the data source, and other details of the email message. |  |
