Siebel Applications Administration Guide > Web Services >
Connecting the Excel Template to Siebel EAI
Before you can connect an Excel template to the Siebel Enterprise Application Integration (EAI) component, you must make sure that particular conditions are met. For more information about these requirements, see Requirements for Connecting Templates to Siebel EAI. This task is a step in Process of Configuring Excel Web Service. To connect an Excel template to Siebel EAI
- In Excel, open the workbook template.
- Select File, then Properties.
- Click the Custom tab.
- Create custom properties with values in the following table.
SFAServer |
ServerName/eai_language, where ServerName is the name of your server, and language is the language of the Siebel Application Object Manager. |
SFAProtocol |
http |
SFAPort |
port_number, where port_number is the number of the port you want to use. |
- Save the workbook template.
