Siebel Business Process Framework: Workflow Guide > Adding Workflow Process Steps > Adding Steps and Connectors >
Adding a Workflow Process Connector
To define the properties of connector in a workflow process, you can use the Properties window in the Process Designer. For information about connector properties, see the topic about the Connector object type in Siebel Object Types Reference. For information about defining a run-time event on a connector, see Starting a Workflow Process from a Run-Time Event.
