Siebel Business Process Framework: Workflow Guide > Adding Workflow Process Steps > Adding Steps and Connectors >
Defining a Property for a Workflow Process Step
The properties of a workflow process step can include input and output arguments, search specifications, operations, and so on. To define some of these properties, you can use the WF Steps list or the Properties window and the Multi-Value Property Window in the Process Designer. You can define each step property for only one workflow process step at a time. To define a property for a workflow process step
- With the Process Designer open, click the step whose properties you must define.
- Use the Properties window to define properties for the step.
If Siebel Tools does not display the Properties window, then right-click and choose View Properties Window. For more information, see Overview of Workflow Process Steps.
- Use the MVPW to define input arguments, output arguments, and search specifications.
For more information, see Using the Multi Value Property Window.
