Siebel Business Process Framework: Workflow Guide > Administering, Testing, and Migrating Workflow Policies > Monitoring, Testing, Troubleshooting, and Migrating a Workflow Policy > Tracing a Workflow PolicyWhen Siebel CRM starts a Workflow Policies server process, it creates a trace file for the following Siebel Server tasks: You can view trace files for workflow policies and Siebel Server tasks and examine them for error messages and other information. To view trace files for workflow policies and Siebel Server tasks
To view trace files in the Siebel Server
For more information about using trace files, see Siebel System Administration Guide. Log Levels for Tracing and Events for Workflow PoliciesTable 71 describes the events that workflow policies use for logging. Setting a trace level above the default parameter affects performance. It is recommended that you reset the trace level to the default parameter after you finish troubleshooting. |
| Siebel Business Process Framework: Workflow Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
