Siebel Business Process Framework: Workflow Guide > Administering, Testing, and Migrating Workflow Policies > Administering Workflow Policies > Configuring a Workflow Policy to Run in Batch ModeRunning a workflow policy in batch mode allows you to evaluate more data in the Siebel database and not only the records that call a workflow policy. This configuration is useful if you create a new workflow policy that Siebel CRM must apply to historical data, and for enforcing a workflow policy that includes a date condition. To configure a workflow policy to run in batch mode
If create a batch workflow policy, then you must use an IS ADDED, IS UPDATED, or IS DELETED comparison operator in conjunction with regular workflow policy conditions. These comparison operators are special conditions that Siebel CRM uses for Dynamic mode when it triggers rows to look up regular conditions. Consolidating Email MessagesIf you configure Siebel CRM to consolidate messages, then it sends one email to the recipient that includes information about multiple actions rather than sending information about multiple actions in multiple emails. For example, you can define a workflow policy that sends an email to a sales director each time a sales representative sends a quote that includes a discount over 30%. If 20 sales representatives send quotes that include the 30% discount, and if the Batch Mode field is:
Configuring Batch Mode to Make Sure Siebel CRM Calls a Workflow Policy CorrectlyYou can configure batch mode to make sure Siebel CRM calls a workflow policy correctly. To configure batch mode to make sure Siebel CRM calls a workflow policy correctly
Example of Configuring Batch Mode to Make Sure Siebel CRM Calls a Workflow Policy CorrectlyTable 69 describes an example that demonstrates why a previously existing record that meets the workflow policy conditions does not call the workflow policy. In this example, to monitor a field, Siebel CRM starts a workflow policy that references a business object when the following situations occur:
If an account existed in the Siebel database before you created the workflow policy, and if the account meets the requirements that you define for this workflow policy, then this workflow policy does not start a workflow process for this account. If Siebel CRM creates database triggers for this workflow policy, then the Workflow Monitor Agent evaluates a record only if the user updates it or if the user creates a new record. Old records are not affected. To evaluate an account record that existed before you created the workflow policy, make sure the Batch Mode field is checked for the workflow policy, and that the Workflow Monitor Agent runs with Batch Mode set to TRUE. |
| Siebel Business Process Framework: Workflow Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
