Siebel Business Process Framework: Workflow Guide > Defining Custom Workflow Policies > Process of Planning a Workflow Policy > Determining Requirements for the Workflow PolicyThis task is a step in Process of Planning a Workflow Policy. To determine the requirements for the workflow policy and workflow policy conditions, you can identify the properties of the workflow policy and workflow policy conditions to modify, identify the workflow policy object to monitor in the Siebel database, and determine the duration for the monitoring interval. Table 55 describes an example plan that details the type of information to monitor for the workflow policy. Table 56 describes an example plan for the workflow policy conditions. A workflow policy condition includes an expression. The Condition Field identifies the table column that Siebel CRM monitors in the Siebel database. Siebel CRM reads the value for a workflow policy condition from a drop-down list that it defines at the table column level. The value that the operation requires for the condition that you define must be available in this drop-down list. IN and NOT IN are example values. If these values are not available, then the workflow policy cannot call the workflow policy action. |
| Siebel Business Process Framework: Workflow Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
