Siebel Business Process Framework: Workflow Guide > Options for Configuring a Workflow Process > Starting a Workflow Process > Starting a Workflow Process from Another Workflow ProcessYou can define a workflow process so that it asynchronously starts another workflow process. You configure Siebel CRM to start a workflow process that calls a custom business service. This business service uses the Asynchronous Server Requests business service to start another workflow process. To start a workflow process from another workflow process
If you run the workflow process in the Process Simulator, then Siebel Tools inserts a request in the S_SRM_REQUEST table and starts a Workflow Process Manager task on the Siebel Server. |
| Siebel Business Process Framework: Workflow Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
