Siebel Business Process Framework: Workflow Guide > Manipulating Data in a Workflow Process > Using Process Properties > Arguments That You Can Define for a Process PropertyAn argument is a part of the process property hierarchy that allows you to define values for fields. An argument field is a variable on an argument that allows you to define a value that determines the parameters of a process property. Table 15 describes how an argument in the MVPW can send data to or from a workflow process step. A workflow process step can include several types of arguments. The type of step determines the arguments that you can define. The Type field for an argument affects other fields in the argument that you must define. For more information, see Defining a Step Argument in the MVPW. Input Arguments of the Business Service Step, Sub Process Step, and Wait StepAn input argument allows you to define the value for a field that Siebel CRM must send to the business service method. Many methods require an input argument. For more information, see Input Argument Fields of a Process Property. Output Arguments of the Business Service Step, Sub Process Step, and Siebel Operation StepAn output argument can contain the result of work that the business service method performs. Siebel CRM can store an output argument in a process property. Siebel CRM cannot use a calculated field as a value for an input argument or an output argument. If you must use a calculated value, then use an expression. For more information, see Output Argument Fields of a Process Property. Process Properties of the Business Service StepSiebel CRM can use the process property of a business service step as an input argument or output argument for a business service method. The Data Type field of the process property must contain one of the following values: If Siebel CRM must call a workflow process through a business service, then you can map the data that the input and output property sets contain to or from a process property. This configuration is useful if Siebel CRM must run a workflow process from a script. |
| Siebel Business Process Framework: Workflow Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
