| Siebel Business Process Framework: Workflow Guide > Options for Configuring a Workflow Process > Starting a Workflow Process > Starting a Workflow Process from the Application Object Manager
 Running a workflow process in the Application Object Manager can be useful if Siebel CRM must use a business process with a mobile user or if you must define a business process that includes user navigation. To start a workflow process from the Application Object Manager
Start the workflow process in one of the following ways:
From the Process Simulator
From a script that you define to run locally in the Application Object Manager
From a run-time event with the Processing Mode defined as local synchronous
