Siebel Business Process Framework: Workflow Guide > Options for Configuring a Workflow Process > Starting a Workflow Process > Starting a Workflow Process from a ScriptYou can use Siebel VB or Siebel eScript to start a workflow process from a script. A script can start a workflow process from most locations in a Siebel CRM application or from a program that is external to Siebel CRM. If a workflow process starts from a script, then you can define it to run on the Siebel Server or in the Object Manager. A workflow process that starts from a script runs in Synchronous mode. Note the following:
Starting a Workflow Process from a Script in the Object ManagerThe following example script starts a workflow process named My Account Process that starts in the Object Manager: / Example: Starting a Workflow Process through scripting Starting a Workflow Process from a Script That Sends Field Values to Process PropertiesThe following example script starts a workflow process named My Opportunity Process that starts in the Object Manager. Siebel CRM passes field values to the process properties that are defined in the workflow process: //Example: Passing Field Values to Process Properties Using the Server Requests Business Service to Start a Workflow Process from a ScriptYou can use the Server Requests business service to asynchronously start a workflow process from a script. For more information, see Using the Server Requests Business Service to Start a Workflow Process from a Script. |
| Siebel Business Process Framework: Workflow Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
