Siebel Business Process Framework: Workflow Guide > Options for Configuring a Workflow Process > Starting a Workflow Process > Other Configurations That Start a Workflow ProcessFor information about other ways to start a workflow process, see the following topics:
You can use these configurations to test a workflow process in your test environment before you deploy it to the production environment. When testing, being able to start a workflow from a workflow policy is important because it tests starting a workflow process on the Siebel Server. You can also use these configurations to start a workflow process in your production environment. Using the Business Integration Manager to Start a Workflow ProcessIt is recommended that you do not use Business Integration Manager or Business Integration Batch Manager: |
| Siebel Business Process Framework: Workflow Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
