Siebel Business Process Framework: Workflow Guide > Options for Configuring a Workflow Process > Handling ErrorsThis topic includes the following topics:
An error is a deviation from the normal or expected flow of a workflow process. You can use error handling to notify the user that an error occurred and to terminate the workflow process. For information about using a process property when handling errors, see Passing Data Through a Process Property to an Error-Workflow Process. |
| Siebel Business Process Framework: Workflow Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
