Siebel Business Process Framework: Workflow Guide > Example Workflow Processes > Defining a Workflow Process That Creates an Activity for a Sales Representative > Deploying and Verifying the Workflow ProcessThis task is a step in Defining a Workflow Process That Creates an Activity for a Sales Representative. In this topic you deploy the workflow process and to verify that it implements the required functionality. To deploy and verify the workflow process
If you must modify the workflow process, then you can click Revise on the WF/Task Editor toolbar in Siebel Tools. For more information, see Using Process Properties and Revising a Workflow Process. |
| Siebel Business Process Framework: Workflow Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
