Siebel Business Process Framework: Workflow Guide > Example Workflow Processes > Defining a Workflow Process That Creates an Activity for a Sales Representative >
Simulating the Workflow Process
This task is a step in Defining a Workflow Process That Creates an Activity for a Sales Representative.
In this topic you simulate the workflow process, and then examine simulation results.
To simulate the workflow process
  1. Use the Process Simulator to step through the entire workflow process.
    For more information, see Preparing to Use the Process Simulator.
  2. In the Siebel client, navigate to the Opportunities screen.
  3. In the Opportunities list, drill down on the opportunity named Large Opportunity to Test Workflow.
  4. Click the Activities view tab.
    A new Activity must exist and it must contain the description you defined in Defining Properties and Arguments for Workflow Process Steps. If it does, then the simulation finishes successfully.
  5. Remove the modifications you made for testing:
    1. In Siebel Tools, close the Simulator.
    2. In the WF Process Props list, choose the Object Id process property for your workflow process.
    3. In the Properties window, delete the row ID in the Default String property.
    4. In the WF Process Props list, step off the record to save your changes.
Siebel Business Process Framework: Workflow Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
