Siebel Business Process Framework: Workflow Guide > Example Workflow Processes > Defining a Workflow Process That Attaches an Activity Plan to an Opportunity > Preparing Example Data for the SimulationThis task is a step in Defining a Workflow Process That Attaches an Activity Plan to an Opportunity. Before you can test the workflow process, you create an opportunity that matches the test criteria. You create this opportunity, and then note the Row Id of the opportunity. To run the test, you then use this Row Id in the properties of the workflow process. To prepare example data for the simulation
| Siebel Business Process Framework: Workflow Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
