Siebel Business Process Framework: Workflow Guide > Example Workflow Processes >
Defining a Workflow Process That Manages Research Activities for a Service Request
In this topic you create a workflow process that manages research activities for a service request. To develop this example, do the following tasks:
- Creating the Workflow Process
- Configuring the Workflow Process Steps and Connectors
- Testing, Deploying, and Verifying the Workflow Process
In this example, a workflow process detects if user takes ownership of a service request, and then creates an activity of type Research. It then provides the service request owner with items that the owner can use to research the service request. You define a simple workflow process that a run-time event starts. You become familiar with the items that are involved in setting up this workflow process and you make sure that the workflow process and the run-time event work correctly.
