Siebel Business Process Framework: Workflow Guide > Example Workflow Processes > Defining a Workflow Process That Manages Research Activities for a Service Request >
Testing, Deploying, and Verifying the Workflow Process
This task is a step in Defining a Workflow Process That Manages Research Activities for a Service Request. In this topic you test, deploy, and verify the workflow process. To test, deploy and verify the workflow process
- Validate, and then simulate the workflow process.
For more information, see Process of Testing a Workflow.
- Navigate to the Workflow Processes list.
- Query the Process Name property for the SR Assigned-Auto Create Activities workflow process.
- Deploy the workflow process.
For more information, see Process of Deploying a Workflow Process.
- If you must debug the workflow process, then, in the Siebel client, in the Active Workflow Processes list, set the Monitoring Level to 4-Debug.
For more information, see Diagnosing a Workflow Process That Has Failed.
- Verify that the workflow process implements the required functionality:
- In the Siebel client, navigate to the Service Requests screen, and then the All Service Requests view.
- Create a new service request, and then step off the record.
- In the Service Request list, click the link in the SR # field.
- Examine the Activities tab.
If the workflow runs correctly, then Siebel CRM displays the following values in the Activities list:
- Type: Research
- Description: Will research the following: Siebel Bookshelf
