Siebel Business Process Framework: Workflow Guide > Using the Siebel Workflow Development Environment > Locating a Workflow Process in the Workflow Processes List >
Displaying Properties of a Workflow Process
You can define some of properties of a workflow process, but not every property, in the Workflow Processes list, or the Properties window in the Process Designer. The Properties window in the Process Designer displays properties depending on context. To display properties of a workflow process
- Locate the workflow process you must modify.
For more information, see Locating a Workflow Process in the Workflow Processes List.
- Right-click the workflow process, and then choose Edit Workflow Process.
- Click the canvas, making sure no workflow process step or connector is chosen.
- Choose the View menu, Windows, and then the Properties Window menu item.
