Siebel Business Process Framework: Workflow Guide > Using the Siebel Workflow Development Environment >
Locating a Workflow Process in the Workflow Processes List
This topic describes how to locate the object definition for a workflow process. To locate a workflow process in the Workflow Processes list
- Open Siebel Tools.
- If necessary, display the workflow process object hierarchy.
For more information, see Preparing Siebel Tools to Develop a Workflow Process.
- In the Object Explorer, click Workflow Process.
- In the Workflow Processes list, query the Process Name property for the workflow process you must modify.
If the workflow process exists, then Siebel Tools displays the object definition of the workflow process in the Workflow Processes list. Querying for the workflow process in this way results in Siebel Tools displaying a single, isolated record. This configuration helps to make sure that you choose the correct workflow process in the list. It helps to make sure you modify the child objects for this workflow process rather than some other workflow process, or if you do other work, such as publishing or revising.
