Siebel Business Process Framework: Workflow Guide > Using the Siebel Workflow Development Environment > Preparing Siebel Tools to Develop a Workflow Process >
Displaying Object Types You Use to Develop a Workflow Process
This topic describes how to display the object types in the Object Explorer that you use to develop a workflow process. To display object types that you use to develop a workflow process
- Log in to Siebel Tools.
- Choose the View menu, and then the Options menu item.
- Click the Object Explorer tab.
- Scroll down through the Object Explorer Hierarchy window to locate the Workflow Process object type, and then display it by making sure the Workflow Process object and all child objects for it contain a check mark.
- Optional. Repeat Step 4 for each of the following object types that you might use to develop a workflow process:
- Business Object
- Command
- Toolbars
- Workflow Policy Column
- Workflow Policy Object
- Workflow Policy Program
- Click OK.
