Siebel Business Process Framework: Workflow Guide > Using the Siebel Workflow Development Environment >
Preparing Siebel Tools to Develop a Workflow Process
To develop a workflow process, you begin by preparing Siebel Tools. To prepare Siebel Tools to develop a workflow process
- Set the following parameter in the Workflow section of the configuration file of the Siebel application:
VerCheckTime = -1
Setting VerCheckTime to -1 allows you to use the Publish/Activate button. Siebel CRM typically locates the configuration file in the language directory in the client. For example:
Siebel\81\21031\MWC\BIN\ENU\uagent.cfg
where:
- Log in to Siebel Tools.
- Choose the View menu, Toolbars, and then the WF/Task Editor Toolbar menu item.
- Choose the View menu, Toolbars, and then the Simulate menu item.
- Display the object types that you use to develop a workflow process.
For more information, see Displaying Object Types You Use to Develop a Workflow Process.
- If necessary, display business service objects.
For more information, see Making a Business Service Visible to a Workflow Process.
