Siebel Business Process Framework: Workflow Guide > Using the Siebel Workflow Development Environment > Using the Workflow Task Editor ToolbarYou can use the WF/Task Editor Toolbar to deploy a workflow process. Figure 10 includes this toolbar. For information about publishing and activating a workflow process, see Process of Deploying a Workflow Process. Buttons You Can Use on the Workflow Task Editor ToolbarTable 10 describes buttons that you can use on the WF/Task Editor Toolbar. If you hover the mouse over a toolbar icon, then Siebel Tools displays a small pop-up message that identifies the button.
Displaying the Workflow Task Editor ToolbarYou must display the WF/Task Editor Toolbar the first time you use it. For more information, see Preparing Siebel Tools to Develop a Workflow Process. Validating a Workflow ProcessIf you click Publish or Publish/Activate in the WF/Task Editor toolbar, then Siebel Tools validates the workflow process before it publishes this workflow process. For more information, see Validate Tool. Deploying a Workflow Process Beginning with Siebel CRM Version 8.0Beginning with Siebel CRM version 8.0, if you set the VerCheckTime parameter in the Workflow section of the .cfg file to Beginning with Siebel CRM version 8.0, you can use the Publish and Publish/Activate buttons to deploy a workflow process. The following occurs in releases prior to Siebel CRM Version 8.0:
Copying Instead of Revising a Workflow ProcessIn some situations, you can copy an existing workflow process rather than revising it. The copy feature allows you to continue to work on the original workflow. For an example, see Modifying the Existing Workflow Process. |
| Siebel Business Process Framework: Workflow Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
