Siebel Business Process Framework: Task UI Guide > Developing a Task UI > Process of Creating a Task UI >
Preparing Siebel Tools to Create a Custom Task UI
To create a custom task UI, you begin by preparing Siebel Tools.
To prepare Siebel Tools to create a custom task UI
  1. Make sure the following parameter is set in the Siebel section of the tools.cfg file in the \TOOLS_ROOT\bin\language directory:
    EnableToolsConstrain = FALSE
    If this parameter does not exist, then add it. Setting EnableToolsConstrain to false allows you to assign a display name to a task object.
  2. Set the following parameter in the Workflow section of the configuration file:
    VerCheckTime = -1
    Setting VerCheckTime to -1 (negative one) allows you to use the Publish/Activate button. The configuration file is typically in the language directory on the client. For example:
    Siebel\81\21031\MWC\BIN\lang\configuration file
    where:
    • lang is the language directory, such as ENU.
    • configuration file is the configuration file for the Siebel application, such as uagent.cfg.
  3. Display object types that you use to develop a task UI.
    For more information, see Displaying Object Types You Use to Develop a Task UI.
  4. If necessary, display business service object types.
    A business service object can include hidden properties. To display hidden properties in a list in Siebel Tools for the following objects, make sure the Hidden property of the object is set to FALSE:
    • Business service
    • Business service method
    • Business service method argument
      For more information, see Siebel Business Process Framework: Workflow Guide.
Siebel Business Process Framework: Task UI Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
