Siebel Business Process Framework: Task UI Guide > Using the Development Environment to Develop a Task UI >
Displaying Object Types You Use to Develop a Task UI
This topic describes how to display the object types in the Object Explorer that you use to develop a task UI. Figure 11 includes the object hierarchy of the Task object type. For more information, see Siebel Object Types Reference.
Figure 11. Hierarchy of the Task Object Type in the Object Explorer
To display object types you use to develop a task UI
  1. Open Siebel Tools.
  2. Choose the View menu, and then the Options menu item.
  3. Click the Object Explorer tab.
  4. To locate the Task tree, scroll down through the Object Explorer Hierarchy window, and then make sure the Task tree and all child objects of the Task tree include a check mark.
  5. Repeat Step 4 for the following object types:
    • Task Group and all children of the task group object type.
    • View and all children of the view object type.
  6. Optional. Display other object types that you might use to develop a task UI:
    1. Expand the Applet tree, and then make sure the Applet Message tree and all child object types of the Applet Message object type include a check mark.
    2. In the Applet tree, make sure Applet User Prop includes a check mark.
    3. In the Applet tree, expand the Control tree, and then make sure Control User Prop includes a check mark.
    4. Collapse the Applet tree, expand the Business Component tree, and then make sure Business Component User Prop includes a check mark.
    5. Collapse the Business Component tree.
    6. Scroll down through the Object Explorer Hierarchy window, and then make sure the Symbolic String tree and all child object types of the Symbolic String object type include a check mark.
  7. Click OK.
Siebel Business Process Framework: Task UI Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
