Table 10. Some Menu Items That the Right-Click Menu Displays in the Tasks List
New Record |
Creates a new object definition for a task UI. For more information, see Using the Tasks List to Create a Custom UI. |
Delete Record |
Deletes a task UI. If the status for a task UI is Completed, then you cannot delete it. You can do the following work to delete a completed task:
- Click Expire in the WF/Task Editor toolbar. This command modifies the Status property for the task to Not In Use.
- Delete the task.
Copy Record |
Copies a task UI. Does a cascade copy of an existing task UI. A cascade copy copies the object definition for the task UI and the object definitions of the child objects of this task UI. You must rename the new copy immediately after the cascade copy finishes to make sure the new copy is unique. |
Add to Archive |
Archives a task UI in a SIF file. For more information, see the topics about working with archive files in Using Siebel Tools. |
Validate |
Validates a task UI. For more information, see Validating a Task UI. |
Edit Task Flow |
Opens the Task Editor for a task UI. For more information, see Using the Task Editor. |
Reset Version |
Resets the version number of a task UI to 0. You can reset the version only if the original version 0 of the task UI no longer exists in the SRF (Siebel Repository File). |
