Siebel Business Process Framework: Task UI Guide > Using the Development Environment to Develop a Task UI > Using the WF/Task Editor Toolbar >
Revising a Task UI
You can use the WF/Task Editor toolbar to revise a task UI. To revise a task UI
- In Siebel Tools, in the Object Explorer, click Project.
- In the Projects list, query the Name property of the project that includes the task UI you must modify.
- To lock the project, click the Locked property.
The Locked property must include a check mark.
- Locate the task UI you must modify.
For more information, see Locating a Task UI in the Tasks List.
- To create a new version of the task UI that you can edit, click the Revise button in the WF/Task Editor toolbar.
Starting with Siebel CRM version 8.1.1.9, you can compare different versions of a task UI. For more information, see the topic about Comparing Different Versions of a Workflow Process or Task UI in Using Siebel Tools.
- Make your modifications in the new version of the task UI.
- Deploy the task UI.
For more information, see Process of Deploying a Task UI.
- Unlock the project you locked in Step 3.
