Siebel Business Process Framework: Task UI Guide > Using the Development Environment to Develop a Task UI > Using the WF/Task Editor Toolbar > Publishing in Local ModeIf you work in local mode and you must use the Publish/Activate button rather than the Publish button, then it is not necessary to activate the task UI separately in the run-time client. |
| Siebel Business Process Framework: Task UI Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
