Siebel Business Process Framework: Task UI Guide > Using the Development Environment to Develop a Task UI >
Wizards You Use to Create a Task UI
You can use the following wizards to help create a task UI:
- Task Wizard. Helps you create an object definition for a task UI, including the first steps that you must include to run a task.
- Task Applet Wizard. Helps you create a task applet.
- Task View Wizard. Helps you create task UI views, and makes sure you include and display the objects that each task UI requires.
- Transient Business Component Wizard. Helps you create a transient business component and fields for the transient business component, making sure you use the correct classes, table, and class set. For more information, see Overview of Transient Data.
