Siebel Business Process Framework: Task UI Guide > Using the Development Environment to Develop a Task UI > Using the Task Editor >
Adding a Step to a Task UI
You can use the Task Editor to add a step to a task UI. You add a step, and then use the Properties window to define properties for this step. In some situations, you can use the Task Steps list to define properties for a step. You save the task UI, and then Siebel Tools displays a record for the new step in the Task Steps list, where you can modify properties.
To add a step to a task UI
  1. Locate the task UI you must modify.
    For more information, see Locating a Task UI in the Tasks List.
  2. If the value in the Status property of the task UI is Completed or Not In Use, then click Revise in the WF/Task Editor Toolbar.
    For more information, see Using the WF/Task Editor Toolbar.
  3. Open the Task Editor.
    For more information, see Opening the Task Editor.
  4. Drag the step type you must add from the Task Palette and drop it on the canvas.
    For more information, see Overview of Step Types.
  5. In the Properties window, enter or modify the Name property.
    If you step out of the property, then Siebel Tools updates the step name in the canvas.
  6. Optional. Enter a description of the purpose of the step.
  7. Define other properties for the step, as necessary.
Siebel Business Process Framework: Task UI Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
