Siebel Business Process Framework: Task UI Guide > Using the Development Environment to Develop a Task UI > Using the Task Editor > Opening the Task EditorYou can open the task editor for a task UI.
If a limited amount of space exists on your monitor, then you can stack the Object Explorer, Palette window, and Properties window on top of each other. You can then access each window through tabs near the bottom of Siebel Tools. For more information, see Using Siebel Tools. |
Siebel Business Process Framework: Task UI Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
