Siebel Business Process Framework: Task UI Guide > Using the Development Environment to Develop a Task UI > About the Task Property > Task Property and the Property SetA task property is an object that stores a value that the task UI gets from the Siebel database or gets before or during processing. The following examples describe some of the ways that Siebel CRM can use a task property:
The final value of each task property is available as a separate output argument when a task UI finishes. You can configure Siebel CRM to pass this value to other objects.
How a Task Property WorksA property set is a hierarchical structure that includes task properties, which are multiple sets of name and value pairs. A property set can include these task properties at each level in the hierarchy. Siebel CRM uses the property set to pass data between steps in a task UI. Figure 12 illustrates how Siebel CRM uses a task property. Explanation of CalloutsThe following steps describe an example of how Siebel CRM uses a task property:
Table 6 describes how a task property manages property sets in two different ways. |
| Siebel Business Process Framework: Task UI Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
