Siebel Business Process Framework: Task UI Guide > Testing, Troubleshooting, Deploying, and Administering a Task UI > Troubleshooting a Task UI >
Build View Errors Occur with Task UI
The following build view errors might occur if the user navigates through a task UI, and if the mode for this task UI is set to In Task UI:
  • Siebel CRM does not delete the previous view so an active view still exists. In this situation, Siebel CRM displays a dialog box in the Siebel client. You can dismiss the message, correct the problem, and then try to navigate or cancel the task UI.
  • Siebel CRM deletes the previous view, so no active view is available. In this situation, Siebel CRM displays an HTML page in the Siebel client that describes the error.
Siebel Business Process Framework: Task UI Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
