Table 16. Other Problems That Can Occur When You Develop a Task UI
A text field does not display properly when a task UI runs. The task UI uses a transient business component with this text field. |
Modify the property of the field to Text. The default is RadioButton. |
You cannot find a transient business component in the Business Component property of a task step. |
Add the transient business component to the corresponding business object:
- In the Object Explorer, expand the Business Object tree, and then click Business Object Component.
- In the Business Object Components list, add the required configuration.
Siebel CRM does not display a Task applet while you define a view. |
Choose the task UI that Siebel CRM links to the applet. |
A task step includes a forward button type of Submit. |
Choose a view step and modify the type to Submit. For more information, see Validation with Forward Navigation in the Task Playbar. |
Siebel CRM does not list a task UI in the Application - Administration screen, Tasks view. |
Publish and activate the task UI. |
A transient business component is missing when a task UI runs. |
The Siebel client does not display views or applets that you defined. |
Do the following work:
- Make sure you registered the views or applets in the Views view of the Application - Administration screen.
- Make sure you compiled the views and applets to the SRF.
- Make sure the responsibility for the user possesses the visibility to and can run the task UI. For more information, see Adding a Responsibility to a Task UI.
Siebel CRM does not display the name of the task group in the task pane. |
Define a display name, and then update the display name in the task group. |
Siebel CRM does not display the task group in the task pane. |
Make sure you add the task group to the standard UI. |
Siebel CRM does not display the task UI in the task group. |
Add the task UI to the task group, and then compile your modifications. |
Siebel CRM does not display the task group or the name of the task UI in the standard UI. |
Compile the standard UI that contains the objects. |
Siebel CRM does not display chapter definitions. |
For more information, see Creating a Task Chapter. |
Siebel CRM does not display a view name. |
Define a display name and update the display name in the view. |
Siebel CRM displays an error that indicates that a required field includes no data. |
Set the Defer Write Record property on the Siebel operation step to TRUE. For more information, see About the Defer Write Record Property. |
A condition does not include a condition that matches a run-time value. |
For more information, see Creating a Branch Connector. |
