Siebel Business Process Framework: Task UI Guide > Testing, Troubleshooting, Deploying, and Administering a Task UI > Process of Testing a Task UIThis process is a step in Roadmap for Developing a Task UI. To test a task UI, perform the following tasks:
You must test a task UI before you deploy it. Testing a task UI verifies that the task UI you release to the production environment runs properly and does not cause conflicts with another existing task UI. This topic also describes how to modify data that Siebel CRM collects during testing. For more information, see Modifying How Siebel CRM Logs Data During Testing. |
| Siebel Business Process Framework: Task UI Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
