Siebel Business Process Framework: Task UI Guide > Testing, Troubleshooting, Deploying, and Administering a Task UI > Process of Testing a Task UI >
Verifying Functionality of a Task UI
This task is a step in Process of Testing a Task UI. To finish testing for a task UI, you can verify that the task includes the functionality that is required to meet your business requirements. You run the task in the Siebel client, and then verify that the task functionality matches the functionality that you described during the planning phase. To view an example, see Verifying the Task UI.
