Siebel Business Process Framework: Task UI Guide > Testing, Troubleshooting, Deploying, and Administering a Task UI > Administering a Task UI > Removing Temporary Data After a Task UI FinishesSiebel CRM stores temporary data for a task instance in the S_TU_LOG table. The user finishes a task instance, and then the Siebel Object Manager clears the temporary data. This behavior varies depending on the following data source where the user connects:
You can run the Task Log Cleanup Service business service to manually delete temporary data that Siebel CRM stores for a finished task instance. This service allows you to specify when Siebel CRM deletes temporary data rather than performing the delete at a predefined interval. For more information, see Transparent Storage. To remove temporary data after a task UI finishes
| Siebel Business Process Framework: Task UI Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
