 Siebel Communications Guide > Defining Billing Profile Workflows for Siebel Communications  > Workflows to Enter Adjustments in the Billing Profile Portal >
CMUEventDetailsAdjustmentWF
This workflow creates appropriate adjustment request detail when a user adjusts bill events. Figure 39 shows this workflow. A user initiates this workflow by clicking the Adjust button for events relating to a bill.
Figure 39.	CMUEventDetailsAdjustmentWF Workflow
 Workflow Description. This workflow performs the following actions:
- Create Invoice Header. Calls the CMUInvoiceQueryWF workflow to check if the bill exists in the Siebel database. If the bill does not exist, then it creates the bill header. For more information, see CMUInvoiceQueryWF Workflow.
 - Create Invoice Line Item. Calls the CMUItemChargeQueryWF workflow to check if the item charge exists in the Siebel database. If the item charge does not exist, then creates the bill line item. For more information, see CMUItemChargeQueryWF Workflow.
 - Create Invoice Details. Calls the CMUEventDetailsQueryWF workflow to check if the bill event detail exists in the Siebel database. If the bill event detail does not exist, then creates the bill event detail. For more information, see CMUEventDetailsQueryWF.
 - Create Adjustment Header. Creates the adjustment request header and populates some of the header fields.
 - Create Adjustment Line Item. Creates the adjustment request line item, and defaults the Request Amount and the Approved Amount to 0.
 - Goto Adjustment View Sub Process. Calls the CMU Adjustment View Sub Process to navigate to the adjustment view. For more information, see CMU Adjustment View Sub Process Workflow.
Associated Business Service Methods. The following table shows the steps in this workflow that call business service methods.
    Create Invoice Header  |
    CMUInvoiceDataTransfer  |
    CMU Util UI Service  |
    Create Invoice Line Item  |
    Create Invoice Details  |
    Create Adjustment Header  |
    CMUAdjustmentDataTransfer  |
    Create Adjustment Line Item  |
