Siebel Communications Guide > Overview of Siebel Communications > Configuring Communications, Order-to-Cash, and Master Data Management Integration > Changing the Default Billing Type to SubscriptionThe Service Bundle billing type is the default setting for the SIS OM Add Service Charge Sub-Process workflow. You can change this workflow to apply the Subscription billing type instead. For more information about the SIS OM Add Service Charge Sub-Process workflow, see Siebel Order Management Guide Addendum for Communications. For information about changing and redeploying a workflow process, see Siebel Business Process Framework: Workflow Guide. To change the default billing type to Subscription
Siebel Communications Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
