Siebel Communications Guide > Overview of Siebel Communications > Configuring Communications, Order-to-Cash, and Master Data Management Integration >
Activating the Oracle Application Integration Architecture-Related Workflows
To configure the Siebel UI elements, follow this procedure.
To activate the Oracle Application Integration Architecture-related workflows
  1. Modify workflows to enable the UTC date format by completing the following steps:
    1. In each of the following workflows, change the UTCCanonical process property value from N to Y using Siebel Tools:
      CMU Credit Alert Status Sync
      CMU SIA Submit Adjustment Request to External
      SISOMBillingSubmitOrderWebService
      SWI Account Update Workflow
      SWI Billing Profile Update Workflow
      SWI Contact Update Workflow
      SWI Address Update Workflow
      SWI Cancel Sales Order_O2C
      SWI External Account Request Sync Process
      SWI External Contact Request Sync Process
      SWI Special Rating - Synchronize Process
      SWIAdjustmentStatusUpdate
      SWIOrderUpsert
      SWIOrderUpsert_O2C
      SWIOrderUpsertSubProcess
      SWIQuoteUpsert
      SWISendATPCheck
      SWISendATPCheckLine
      SWISendCalculateShippingCharge
      SWISendCreditCheck
      SWISendOrder
      SWISendPaymentAuthorization
      SWISendQuote
    2. Publish the workflows.
  2. Confirm that the workflows listed in the following table are active.
    Workflow Name
    Project
    *SIS OM Disconnect Asset Sub-process
    SIS OM Base Architecture
    *SIS OM Move Process
    ABO Bulk Request -Validate Process
    ABO Bulk Request
    ABO Bulk Request - Clear Exception Process Workflow
    ABO Bulk Request
    ABO Bulk Request - Parallel Sub Process Workflow
    ABO Bulk Request
    ABO Bulk Request - Prepare Action Set Sub-Process Workflow
    ABO Bulk Request
    ABO Bulk Request - Submit Process Workflow
    ABO Bulk Request
    ABO Bulk Request Add Item Customize Process
    ABO Bulk Request
    Account - New Order
    COM Workflows
    Basic Pricing Procedure
    Cfg RTC
    Web Service Integration
    CMU Billing Integration
    CMUBalanceDetailsEventAdjustmentWF
    CMUEventDetailsAdjustmentWF
    CMUInvoiceAdjustmentWF
    CMUItemChargeAdjustmentWF
    CMUUnbilledEventAdjustmentWF
    CMUUnbilledNonCurrencyEventAdjustmentWF
    CZ PSP Interface
    CZ Return
    Dynamic Pricing Procedure
    Row Set Transformation Toolkit
    ISS Promotion Disconnect Process
    ISS Promotion Workflow
    ISS Promotion Upgrade Process
    Oracle Configurator Load
    Oracle Verify Complex Product All (Order)
    Oracle Verify Complex Product All (Quote)
    Oracle Verify Header (Order)
    Oracle Verify Header (Quote)
    Oracle Verify Item (Order)
    Oracle Verify Item (Quote)
    Pricing Procedure - Calculate Net Price
    SIA External Integration Process
    Prepaid Service 8.1
    SIS OM Add Service Charge Order Sub-Process
    SIS OM Add Service Charge Quote Sub-Process
    SIS OM Add Service Charge Sub-Process
    SIS OM Disconnect Products & Services Process
    SIS OM Edit Complex Asset Workflow
    SIS OM Edit Delta Quote Line Item
    SIS OM Edit Service Order Line Item
    SIS OM Modify Products & Services Process
    SIS OM Order Line Item Update Main
    SIS OM Submit Order Process
    SIS OM Suspend / Resume Asset Sub-Process
    SIS OM Suspend / Resume Products & Services Process
    Submit Order ASI
    COM Workflows
    Submit Quote ASI
    COM Workflows
    SWI Asset Status Update
    SWI Cancel Sales Order Line Item
    SWI Configurator Load
    SWI External Account Integration Process
    SWI External Contact Integration Process
    SWI External Contact Req Integration Process
    SWI External Customer Req Integration Process
    SWI External Product Sync Workflow
    SWI Initial Load Non CP Order Release
    SWI Parent Order
    SWI TSQ Order
    SWICancel Sales Order
    SWICopyOrder
    SWIOrderUpsert
    SWIOrderUpsert_O2C
    SWIQuoteUpsert
    SWIReviseOrderValidation
    SWISendATPCheck
    SWISendATPCheckLine
    SWISendCreditCheck
    SWISendOrder
    SWISendQuote
    SWISetTBOEndDate
    SWIValidateDependentOrders
    COM Workflows
    Verify Item (Order)
    COM Workflows
  3. Check the status of each workflow process listed in Step 1. If it is In-Progress, then make it Completed by deploying the workflow process. If the import of any of the workflows fails, then manually activate them within the Siebel application by performing the following steps:
    1. Log in to the Siebel application as an administrator.
    2. Navigate to the Administration - Business Process screen, Workflow Deployment, and then the Repository Workflow Processes view.
    3. Query for the workflow processes and activate them by selecting them and clicking Activate.
      NOTE:  It is recommended that you reload the runtime events after activating the workflows.
Siebel Communications Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
