Siebel Communications Guide > Overview of Siebel Communications > Configuring Communications, Order-to-Cash, and Master Data Management Integration >
Advanced Queue Configuration
The subtopics in this topic describe how to perform advanced queue configuration. Configuring Java Subsystem for Fusion Middleware 10g Integration
In addition to performing the setup tasks for integrating Fusion Middleware in the Siebel installation guide, perform the following procedure. NOTE: Paths in this procedure assume you are running the Siebel Server on the Windows operating system. They must be modified whether the Siebel Server is running on a UNIX operating system.
To configure Java subsystem for Fusion Middleware 10g Integration
- Extract oc4j-extended.zip the following location to a folder in a computer where the Siebel Server is installed, such as
D:\JMS folder.
http://download.oracle.com/otn/java/oc4j/101330/oc4j_extended_101330.zip
- Copy Siebel.jar and SiebelJI_enu to
D:\JMS folder, these jar files can be found in Siebel Server installation directory \classes folder
- Copy jndi.jar file from FMW to
D:\JMS\j2ee\home\lib folder.
- Copy com/evermind/util/JCAProperties.class from the oc4j-internal.jar file to the
D:\JMS folder.
- Create a file with name jndi.properties with following details in the path
D:\JMS :
java.naming.factory.initial=com.evermind.server.rmi.RMIInitialContextFactory
java.naming.provider.url=opmn:ormi://IP Address of the FMW server:OPMN Port No:oc4j_soa
java.naming.security.principal=anonymous
For example:
java.naming.provider.url=opmn:ormi:// 152.68.240.154:6009:oc4j_soa
Make sure that there are no extra spaces in the jndi.properties file.
- Create a Named Subsystem in the Siebel application through the server management by completing the following steps:
- Connect to the server manager from the command prompt from the bin directory of the Siebel installed folder with the following command.
Srvrmgr /g gatewayserver /e enterpriseserver /s siebelserver /u userid /p password
Example: srvrmgr /g sdc78198svqe:4330 /e siebel /s sdc78198svqe /u sadmin /p sadmin
- Run the following command to create the named subsystem and add the jar file into the class path.
Create named subsystem JAVA for subsystem JVMSubSys with DLL=C:\Sun\SDK\jdk\jre\bin\server\jvm.dll, CLASSPATH = D:\JMS;D:\JMS\Siebel.jar;D:\JMS\rdbms\jlib\aqapi.jar;D:\JMS\jdbc\lib\ocrs12.jar;D:\JMS\jdbc\lib\ojdbc14dms.jar;D:\JMS\jdbc\lib\orai18n.jar;D:\JMS\SiebelJI_enu.jar;D:\JMS\j2ee\home\lib\adminclient.jar;D:\JMS\j2ee\home\lib\jndi.jar;D:\JMS\j2ee\home\lib\jta.jar;D:\JMS\j2ee\home\oc4jclient.jar;D:\JMS\j2ee\home\lib\bcel.jar;D:\JMS\j2ee\home\lib\jms.jar;D:\JMS\j2ee\home\lib\javax77.jar;D:\JMS\lib\dms.jar;D:\JMS\opmn\lib\optic.jar;D:\JMS\j2ee\home\lib\ejb.jar;., VMOPTIONS= D:\JMS\log\jms.log
For the UNIX environment the CLASSPATH is separated by : (colon). For the Windows environment it is separated by ; (semicolon). So, the above command for UNIX environment follows:
Create named subsystem JAVA for subsystem JVMSubSys with DLL= /usr/jdk1.5.0_06/jre/lib/sparc/client/libjvm.so, CLASSPATH = /export/home/qa1/JMS:/export/home/qa1/JMS/Siebel.jar:/export/home/qa1/JMS/rdbms/jlib/aqapi.jar:/export/home/qa1/JMS/jdbc/lib/ocrs12.jar:/export/home/qa1/JMS/jdbc/lib/ojdbc14dms.jar:/export/home/qa1/JMS/jdbc/lib/orai18n.jar:/export/home/qa1/JMS/SiebelJI_enu.jar:/export/home/qa1/JMS/j2ee/home/lib/adminclient.jar:/export/home/qa1/JMS/j2ee/home/lib/jndi.jar:/export/home/qa1/JMS/j2ee/home/lib/jta.jar:/export/home/qa1/JMS/j2ee/home/oc4jclient.jar:/export/home/qa1/JMS/j2ee/home/lib/bcel.jar:/export/home/qa1/JMS/j2ee/home/lib/jms.jar:/export/home/qa1/JMS/j2ee/home/lib/javax77.jar:/export/home/qa1/JMS/lib/dms.jar:/export/home/qa1/JMS/opmn/lib/optic.jar:/export/home/qa1/JMS/j2ee/home/lib/ejb.jar:., VMOPTIONS= /export/home/qa2/JMS/log/jms.log
Make sure that the path is correct for all the files and that the CLASSPATH ends with a . (dot). Replace qa2 with the appropriate folder name.
- Log in to the Siebel application and navigate to the Administration - Server Configuration screen, Enterprises, and then the Profile Configuration view, and complete the following steps:
- Query for the Profile with Alias Name JAVA in the profile list and make sure the parameters are correct.
- For the Windows environment, edit the value of VMOPTIONS to:
-Djms.log=D:\JMS\log\jms.log
- For the Solaris environment, edit the value of VMOPTIONS to:
-Xusealtsigs -Xrs -Djms.log=/export/home/qa2/JMS/log/jms.log .
Make sure that the JMS/log folder exists and has the write permission.
- Restart the Siebel Server.
NOTE: For more information, see the Siebel Enterprise Application Integration (EAI) documentation on the Siebel Bookshelf.
Configuring Corresponding Web Services for Advanced Queue
This topic contains information about how to configure corresponding Web services for AQ. AQ configuration involves configuring JMS messaging between Siebel Business Applications and the Oracle SOA suite using Oracle Advanced Queuing. For more information about this configuration, see Transports and Interfaces: Siebel Enterprise Application Integration. Use the following procedure to configure corresponding Web services for AQ. To configure corresponding Web services
- Navigate to the Administration - Web Services screen, then the Outbound Web Services view and query for SWI*.
- Change the transport to JMS and address as:
jms://queue name @connection factory
queue name is in the following format:
java:comp/resource/ Resource Provider Name as configured /Queues/queue name
connection factory is in the following format:
java:comp/resource/Resource Provider Name as configured /QueueConnectionFactories/QCF
Queues must have been created as part of Oracle Application Integration Architecture installation. Refer the queue name in this step.
- To locate the Connection Factory Name, log in to Application Server control, and navigate to oc4j_soa ' Administration, then Database Persistence.
Here you can find the Resource Provider Name if it is configured.
Example: jms://java:comp/resource/AIA_JMS_RP/Queues/AIA_SALESORDERJMSQUEUE@java:comp/resource/AIA_JMS_RP/QueueConnectionFactories/QCF
- After changing the address, click Clear Cache.
- If you are using the Communications PIP or the Order-To-Cash PIP, then proceed to one of the following steps:
- Communications PIP. Go to Step 6.
- Order-To-Cash PIP. Go to Step 7.
- For the Communications PIP, configure the following Web services:
- SWICreateAdjustment
Example for FMW 10g:
jms://java:comp/resource/AIA_JMS_RP/Queues/AIA_CMUREQADJIOJMSQUEUE@java:comp/resource/AIA_JMS_RP/QueueConnectionFactories/QCF
Example for FMW 11g:
jms://jms/aia/AIA_CMUREQADJIOJMSQUEUE@jms/aia/COMMS_ADJUSTMENT_CONSUMER
- SWISpecialRatingList
jms://jms/aia/AIA_SPECIALRATINGJMSQ@jms/aia/COMMS_SPECIALRATINGLIST_CONSUMER
- SWISubmitOrder
jms://jms/aia/AIA_SALESORDERJMSQUEUE@jms/aia/COMMS_SUBMITORDER_CONSUMER
- For the Order-To-Cash PIP, configure the following Web services:
- SWISubmitOrder_o2c
jms://java:comp/resource/DBConnect/Queues/JMSUSER.AIA_QUOTEJMSQUEUE@java:comp/resource/DBConnect/QueueConnectionFactories/QCF
jms://jms/aia/AIA_SiebelSalesOrderJMSQueue@jms/aia/AIASiebelCF
- SWISubmitQuote_o2c
jms://jms/aia/AIA_SiebelQuoteJMSQueue@jms/aia/AIASiebelCF
Configuring Java Subsystem for Fusion Middleware 11g Integration
In addition to performing the setup tasks for integrating Fusion Middleware in the Siebel installation guide, perform the following procedure. NOTE: Paths in this procedure assume you are running the Siebel Server on the Windows operating system. They must be modified if the Siebel Server is running on a UNIX operating system.
To configure Java subsystem for Fusion Middleware 11g Integration
- Get the wlfullclient.jar file from the FMW/AIA team. If you cannot get this file, then perform the following steps to create wlfullclient.jar in the FMW server:
- WinScp to the SOA server.
- Change directories to the
server/lib directory. For example, go to the WL_HOME/server/lib .
- Execute the command:
java -jar wljarbuilder.jar
The wlfullclient.jar file is created.
- Remotely login to the Siebel installed server.
- Get the files Siebel.jar and SiebelJI_enu.jar from the following directory:
siebel installation \ses\siebsrvr\classes
- Copy the wlfullclient.jar, Siebel.jar and SiebelJI_enu.jar to the directory
D:\JMS . If this directory does not exist, then create it.
- Prepare the jndi.properties file with the following values:
java.naming.factory.initial=weblogic.jndi.WLInitialContextFactory java.naming.provider.url=t3://FMW_HOST :SOA_PORT
java.naming.security.principal=UserName
java.naming.security.credentials=Password
NOTE: If Oracle Application Integration Architecture is running in a clustered environment and has a setup proxy host, then jndi.properties have following URL:
java.naming.provider.url=http://FMW_HOST:PROXY_PORT
- Create the JAVA Subsystem using the Siebel Web application as follows:
- Connect to the server manager from the bin directory of the Siebel installed folder by entering the following command from the command prompt:
For example:
- Enter the following command to create the named subsystem:
- Add parameters with the aliases CLASSPATH, DLL, and VMOPTIONS, as described in the tables that follow.
The following table specifies the Name, Data Type, and Value values to enter for the parameters with aliases CLASSPATH, DLL, and VMOPTIONS.
CLASSPATH |
JVM Classpath |
String |
D:\JMS;D:\JMS\Siebel.jar;D:\JMS\SiebelJI_enu.jar;D:\JMS\wlfullclient.jar;.
DLL |
JVM DLL Name |
String |
VMOPTIONS |
JVM Options |
String |
The following table specifies the Scope, Type, Description, and Visibility values to enter for the parameters with aliases CLASSPATH, DLL, and VMOPTIONS.
CLASSPATH |
Subsystem |
JVM Configuration Subsystem |
JVM Classpath |
Basic |
DLL |
Subsystem |
JVM DLL Name |
Basic |
VMOPTIONS |
Subsystem |
JVM Options |
Basic |
- Create the Simulator (with the service name: EAI JMS Transport and Method name: CheckAll).
- In the Input Argument Section, create Test Case 1 with the values in the following table.
PropertySet |
ConnectionFactory |
jms/TestQueueCF |
PropertySet |
SendQueue |
jms/TestQueue |
- Click Run to verify the setup in the simulator.
No error messages appear after the run.
