Configuring Siebel Business Applications > Configuring Lists and Pick Applets > Associating an Organization with a List of Values >
Guidelines for Using Script to Associate a List of Values with an Organization
If you use script to associate a list of values with an organization, then use the following guidelines.
  • If you use LookupValue or LookupName as an expression in a script, and:
    • Data does not exist. Siebel CRM uses the organization that is associated with the current position of the user to determine visibility of the list of values. Creating a new record is an example where data does not exist.
    • Data does exist. Siebel CRM uses the primary organization that is associated with the record to determine visibility of the list of values.
  • If you use LookupValue or LookupName as a function in a repository configuration or a script, then Siebel CRM uses the organization that is associated with the primary position of the user to determine visibility of the list of values.
Configuring Siebel Business Applications Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
