Configuring Siebel Business Applications > Configuring Lists and Pick Applets > Associating an Organization with a List of ValuesThis topic describes how to associate an organization with a list of values. It includes the following topics:
You can define a list of values to display for some organizations but not for other organizations. For example, assume your company includes several subsidiary companies and each subsidiary is defined as an organization in your Siebel deployment. For a list, you can display a different list of values for each member of each organization. To do this, you associate each list of values to an organization. For example, the organization associated with the active position of a user might be Org ABC, but the primary organization that is associated with the record that the user is viewing might be Org XYZ. In this situation, Siebel CRM displays the list of values that it associates with Org XYZ. For more information, see Guidelines for Associating an Organization with a List of Values. For more information about organizations and access control, see Siebel Security Guide. To associate an organization with a list of values
| Configuring Siebel Business Applications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
