Configuring Siebel Business Applications > Configuring Lists and Pick Applets > Configuring Lists and Pick Applets >
Using the Pick List Wizard to Create a Static List
You can use the Pick List Wizard to create a static list.
To use the Pick List Wizard to create a static list
  1. In Siebel Tools, click the File menu, and then click New Object.
  2. Click the Pick List icon, and then click OK.
  3. In the Pick List dialog box, enter the following information, and then click Next:
    • Project.
    • Business Component. Choose the originating business component. This is the parent business component of the field whose values display in the list.
    • Field.
  4. In the Pick List Type dialog box, choose Static, and then click Next.
  5. In the Pick List Definition dialog box, do one of the following:
    • If you must create a new list, then choose Create New Pick List, and then click Next.
    • If you must use a predefined list, then choose the list and the associated list of values you must use, click Next, and then proceed to Step 8.
  6. If you must create a new list of values (LOV), then do the following:
    1. Enter a unique name for the list.
    2. Click Create New List of Values, and then click Next.
    3. In the List of Values dialog box, enter a name for the list of values, and then enter the values.
      For more information, see Creating a New List of Values Locally.
    4. Click Next.
  7. If you must use a predefined list of values, then do the following:
    2. Choose the Use Predetermined List of Values option.
    3. Choose the List of Values Type, and then click Next.
    4. In the third Pick List Definition dialog box, enter a search specification, enter a comment, and then choose to bind or not bind the list. For more information, see Options to Filter Data That Siebel CRM Displays in an Applet.
    5. Click Next.
  8. In the Finish dialog box, review the specifications for the list, and then click Finish.
If you use the Picklist Wizard to create a list of values, and if you store this list of values on your local database, then you cannot use Check In to copy this list of values to the server database. To avoid this situation, you can do one of the following:
  • Use Siebel Remote to synchronize your modifications to the Siebel Server:
    1. On the computer where the S_LOV_OF_VAL records exist, open the Developer Web Client, and then connect to the local database.
    2. Click the File menu, and then click Synchronize Database.
    3. Make sure you clear the cache in the List Of Values view.
  • Create the list of values on the Siebel Server instead of on your local development computer.
For more information, see Creating a List of Values and Siebel Applications Administration Guide.
Configuring Siebel Business Applications Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
