Configuring Siebel Business Applications > Configuring Views, Screens, and Applications > Process of Creating a Screen Home Page View >
This task is a step in Process of Creating a Screen Home Page View.
After you define the business components, business objects, and applets, you can define the screen home page view to display the objects and data in the Siebel client. For more information, see Options to Control How the User Creates, Edits, Queries, and Deletes CRM Data and see Creating a View.
To create a screen home page view
  1. In Siebel Tools, click the File menu, and then click New Object.
  2. In the New Object Wizards dialog box, click the General tab, click View, and then click OK.
  3. Complete the New View dialog box using values from the following table, and then click Next.
    Property
    Description
    Project
    Choose ScreenHomePage.
    Name
    Use the following format:
    • Name of the target business component Screen Homepage View
    For example, Account Screen Homepage View.
    Title
    • Name of the target business component Home
    For example, Account Home.
    Business Object
    Choose the business object for the home page.
    For example, Account. For more information, see Defining the Business Object for the Screen Home Page View.
  4. In the View Web Layout - Select Template dialog box, choose View 25 50 25, and then click Next.
    The View 25 50 25 view web template provides a three column layout.
  5. In the Web Layout - Applets dialog box, move the following applets to the Selected Applets window:
    • Layout Controls Applet or Layout Controls SI Applet
    • Name of the target business component Home Screen Homepage Banner
    • Public and Private View Link List Applet
    • Recent Record Name of the target business component List Applet
    • Screen Home Task Assistant List Applet
    • Name of the target business component Home Search Virtual Form Applet
    • Name of the target business component Home Add Virtual Form Applet Rapid Search Virtual
      For more information about the Rapid Add and Rapid Search applets, see Creating Simplified Screen Home Page Applets.
  6. Click Next, and then click Finish.
  7. In the View Web Layout editor, verify the layout of the screen home page view using values from the following table.
    Applet
    Location
    Rapid Search
    Left top
    Rapid Add
    Left bottom
    Homepage Banner
    Center To
    Center bottom
    Edit Layout
    Right top button
    Right top
    Recent Record
    Right bottom
  8. Close the Web Layout Editor.
  9. In the Object Explorer, expand the View tree, expand the View Web Template tree, and then click View Web Template Item.
  10. In the View Web Template Items list, verify that the Applet Mode and Item Identifier properties are set correctly for each applet. Use values from the following table.
    Applet
    Applet Mode
    Item Identifier
    Rapid Search
    Query
    102
    Rapid Add
    Edit
    103
    Homepage Banner
    Base
    202
    Base
    203
    Edit Layout
    Base
    901
    Base
    302
    Recent Record
    Base
    303
    For more information, see Properties of the Applet Web Template Item.
Configuring Siebel Business Applications Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
