Configuring Siebel Business Applications > Configuring Views, Screens, and Applications > Process of Creating a Screen Home Page View >
Adding the Screen View to the Screen
This task is a step in Process of Creating a Screen Home Page View.
To display the new screen home page view in Siebel CRM, you must create a new Screen View object to represent it.
To add the screen view to the screen
  1. In the Object Explorer, click Screen.
  2. In the Screens list, locate the screen you must modify.
  3. In the Object Explorer, expand the Screen tree, and then click Screen View.
  4. In the Screen Views list, create a new record using information from the following table.
    Property
    Value
    View
    Choose the name of screen view.
    For example, Accounts Screen Homepage View.
    Type
    Aggregate View
    Viewbar Text
    Enter the text that Siebel CRM must display in the viewbar.
    For example, Accounts Home.
  5. Right-click in the Screen Views list, click Edit Screen View Sequence, and then define the sequence for the screen view.
    For more information, see Defining the Sequence That Siebel CRM Uses to Display Screen Views.
  6. Compile and test your modifications.
    For more information, see Using Siebel Tools.
Configuring Siebel Business Applications Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
